Shink Fit Stainless Steel Tube into Inclonel Nozzle
I am trying to determine the Hoop stress between a thin walled stainless steel tube shrunk fit into a thick walled inconel nozzle. I found a formula to use if you are shinking thick wall into thick wall but it doesn't work mixing thin walled into thick walled. Any ideas?
