Condominium Air Conditioning
I am looking for a mid- to high-end, 2-3 ton, vertical S/S AHU for a mid-rise condominium complex. The condensing unit needs to be a thru-wall type. The supply fan must possess 0.5" - 1.0" ESP capabilities. Energy efficiency is also a concern (EER greater than 10.0 desired).
Other than FirstCompany, who makes vertical residential S/S units with thru-wall condensers?
RE: Condominium Air Conditioning
Try this:
http://www.stolway.com.au/index.pl?page=42
http://www.richbeersmarine.com/selfcontained.htm OR
http://www.thermcorp.com/repinfo.htm#download
Good luck!!
