Surge analysis software for hydrocarbons
Hello all,
Can anyone please recommend a decent programme that can handle a variety of fluids from crude oil to Jet A1. Typical models are complex systems with pumps, valves surge tanks, etc. I have shortlisted AFT Impulse and Hytran. I'm in two minds about BOS/Fluids. Ability to import from Rebis AutoPIPE would be a bonus.
Since I will have only one shot at this, professional advise from those in the know would be grately appreciated.
Cheers
Alex
RE: Surge analysis software for hydrocarbons
AFT IMpulse with their Chempak add on will give you all the properties of the fluids you have in mind. On top of that AFT are run by engineers for engineers. They understand hydrocarbons mor e than the run of the mill waterhammer guys because of their background from NASA and the consultancy work they do. On top of that they are available for sdesign verification to close out QA.
They have examples of modelling crude oil lines from ship into tank farms etc.
Hytran is strong in single pipelines and has the added benefit of modelling hydro electric turbines.
I would settle for Impulse if I were you. Unfortunately isnt doesnt have the Rebis interface. This isnt such a drawback as in the world of waterhammer studies yoiu dont want all the piping detail. The detail takes up more computing time and doesnt add to the accuracy of the transient analysis. Often you have to change dimensions of short pipes or even delete short pipes altogether to get reasonable run times.
Building complex models for analysis is a "snack" with object selction capability. Design is where the engineering comes in! No software is going to help you there.
I have  been using Impulse for a number of years and find that they are a great outfit. They are the best software house that I use.
I use flowmaster and/or pipeline syudio. Both programs are good but in the expensive end.
Best regards
Morten
Hi
I have been using BOS/Fluids sence Jan 2003 the program has been upgrade.
Leonard Thill
www.thill.biz
TEAM MEMBERS
PVP - Pressure Vessels & Piping Forum
This Group is for users of the FE/Pipe, NozzlePRO, AxiPRO and BOS Fluids software products from Paulin Research Group, as well as users of any pipe stress analysis program such as CAESAR II, Triflex, Autopipe, CAE Pipe or PipePak. The primary objective is to connect users of the products that have common interests. The group is not associated with Paulin Research Group with the exception of helping get people connected, and informing of updates and meetings. It a great format to share ideas, ask questions, and gain knowledge about uses of the programs and the industries they serve.
Join today CLICK ME
http://www.paulin.com/prg/counter.asp?site=discussion_group.htm
There is a man in the University of Calgary, Canada area who runs a consultancy on mechanical engineering for oil pipelines and teaches some of the terrifying mathematics hydraulics produces who is Cambridge grad and we met in Oct 2003, but I do not know his name, his wife is an archaeologist if that helps. He specializes in your sector question. Try a search mechanical engineering mathematics consultants Calgary. He works US pipeline specialist issues.
mdshydroplane
mdshydroplane
