temperature measurement in a gas turbine combustor
I would like to take temperature measurements in the primary zone of a reverse flow gas turbine combustor. The fuel being used is Paraffin. I am assuming that I need to use a method that can measure in excess of 2000K - Preferably 3000K. Any advice or suggestions of appropriate measuring equipment or techniques would be appreciated.
RE: temperature measurement in a gas turbine combustor
Maybe a high temp thermocouple would do the job, you could do a web search for these.
There is a 900HT series miniature head thermocouple from
www.marshbellofram.com/tcp/catalog/high_temp.htm that may be suitable.
If there is nothing available from there catalouge i'm sure they could tell you who to contact.
Hope this helps
Florida,USA
