Resizing image in Word VB macro
My company recently changed its logo and I now need to change it on hundreds Word documents, in the header.
I wrote a macro to fulfill this task. It works well but just doesnt resize the image. Any help is welcome.
Thanks in advance.
Sub SwapLogo()
' SwapLogo Macro
' Macro enregistrée le 24/02/04 par guichard cyril
'=============== Activation de l'entĂȘte dde document ==========
ActiveWindow.ActivePane.View.SeekView = wdSeekCurrentPageHeader
'=============== Dimensionnement des hauteurs de lignes du tableau ==========
Selection.Cells.HeightRule = wdRowHeightAuto
With Selection.Tables(1).Rows
.Alignment = wdAlignRowLeft
.AllowBreakAcrossPages = True
.SetLeftIndent LeftIndent:=CentimetersToPoints(0.13), RulerStyle:= _
wdAdjustNone
End With
Selection.SelectRow
Selection.Cells.SetHeight RowHeight:=15, HeightRule:=wdRowHeightExactly
With Selection.Rows
wdAdjustNone
End With
Selection.Move Unit:=wdRow, Count:=1
Selection.SelectRow
Selection.Cells.SetHeight RowHeight:=36, HeightRule:=wdRowHeightExactly
With Selection.Rows
wdAdjustNone
End With
Selection.SelectRow
With Selection.Rows
wdAdjustNone
End With
'=============== On efface l'ancien logo ==========
Selection.Cells(1).Select
Selection.MoveUp Unit:=wdLine, Count:=2, Extend:=wdExtend
Selection.Delete Unit:=wdCharacter, Count:=1
'=============== Fusion des cellules ==========
Selection.MoveDown Unit:=wdLine, Count:=1
Selection.Cells.Merge
'=============== Insertion nouveau logo ==========
Selection.InlineShapes.AddPicture FileName:="D:\logos\logo_black.jpg", _
LinkToFile:=False, SaveWithDocument:=True
'=============== Redimensionnement de la colonne =========
Selection.SelectColumn
With Selection.Cells
.SetWidth ColumnWidth:=80, RulerStyle:=wdAdjustFirstColumn
.VerticalAlignment = wdAlignVerticalCenter
End With
Selection.ParagraphFormat.Alignment = wdAlignParagraphCenter
'=============== Redimensionnement du logo =========
Selection.ShapeRange.Select
With Selection.ShapeRange
.ScaleHeight 300, msoFalse, msoScaleFromTopLeft
.ScaleWidth 300, msoFalse, msoScaleFromTopLeft
End With
'=============== Retour au corps de document ==========
ActiveWindow.ActivePane.View.SeekView = wdSeekMainDocument
End Sub
The returned error says the object doesnt exist in the library.
Thanks in advance.
Sub SwapLogo()
' SwapLogo Macro
wdAdjustNone
End With
Selection.SelectRow
With Selection.Rows
wdAdjustNone
End With
Selection.SelectRow
With Selection.Rows
wdAdjustNone
End With
Selection.SelectRow
With Selection.Rows
wdAdjustNone
End With
End With
End With
End Sub
Cyril Guichard
Mechanical Engineer
RE: Resizing image in Word VB macro
Delete the line Selection.ShapeRange.Select, and keep the With ... End With part.
Hope this works, since I couldn't test it, of course.
Salut!
Cheers,
Joerd
Wish their was a Selection.SelectShape available, as there is a Selection.SelectColumn. It would make things alot more easier...
Cyril Guichard
Mechanical Engineer
Can you step through the code and see how the selection changes as you select the table/column/shapes?
Cheers,
Joerd
Cyril Guichard
Mechanical Engineer
