Simple question about units
I´m very new to Abaqus and have a simple question about the units. Is this correct?
When I create the part with "mm"
Material data must be in "MPa"
Density: "g/cm3"
Velocity: "m/s"
Displacement: "mm"
Step Time (explicit): "ms"
the part in "m"
Material: "GPa"
Density: "kg/m3"
Velocity: "m/s"
Displacement: "m"
Step Time: "s"
jhwaxx
Density: "g/cm3"
Velocity: "m/s"
Displacement: "mm"
the part in "m"
Material: "GPa"
Density: "kg/m3"
Velocity: "m/s"
Displacement: "m"
Step Time: "s"
jhwaxx
RE: Simple question about units
-- drej --
corus
i use mm - kg - N for the reason that drej just pointed out being that cae doesnt like small dimensions. but why would density be in tonnes /mm^3 and not kg/mm^3?
thank you,
andi
corus
