where are array buttons in SW2004?
Changing from 2001 to 2004, the thing I can't find is the array feature for either circular or linear arrays.  I have even tried to use the 3D array but it will not accept the hole I have created in the part as a valid starting point.
The help file shows that there should be an array button for this feature but I have not been able to find it.
Thanks for any info.
-Mark
__________________________
Mark Johnson
www.blindchickenracing.com
RE: where are array buttons in SW2004?
You'll need to add those (along with others) back into your tool bars if they aren't shown already.  The quick way is to right-click on a tool bar area and select Customize > Commands.  Then drag what you want to each toolbar.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
If you are not using the command often enough to add it to your toolbars, use the drop down menus.
SW now call this a "Step and repeat".
Tools - Sketch Tools - Linear/Circular Step and Repeat.
Oooooooh, looky...... I just took a peek.  They now have "Edit Linear/Circualr Step and Repeat"  Haven't done one since 2004.  Have they finally got this to a useful tool?!
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There are only 10 types of people in the world - those who understand binary and those who don't.
