Alright my least favorite mis-uses--
Affect and effect......
I can affect a (insert your favorite noun)
I can effect a (insert your favorite verb)
You can affect somthing and cause an effect.
You CAN NOT cause an affect, nor can you effect a thing (noun).
nick
nick
RE: Alright my least favorite mis-uses--
I never could remember the difference without the aid of a dictionary.
I always considered english as a superflous subject, completely without reason nor logic, and a complete waste of time compared to subjects like, geography, math, physics, chemistry, drafting, workshop, sport, sitting in the back of the class making paper aeroplanes, etc. etc.
I must say, I now regret that flaw in my reasoning at the time.
Your explanation will now probably stick in my mind, so as to affect / effect? my future work. Is work a noun or a verb, oh well!
pat
TTFN
Doesn't sound quite right to me. Can anyone effect an example of this useage?
TTFN
JulianHardy: "...effect a modification..."
electricpete: "Where's the verb?" (spoken like the little old lady from Wendy's)
However, “affect” can also be a verb meaning “to make a show of”, or “to prefer or adopt by preference”, or “to assume the character or disposition of” as in: “He affected the facial characteristics of a disgruntled baboon” meaning “He took on the facial characteristics of a disgruntled baboon.”
In this case, one “affects” or adopts a certain characteristic or “affectation” (not an “affection”!) to oneself, rather than “affecting” some other person or thing.
”Effect” is USUALLY a noun meaning “that which is caused by some agency or cause” or “the result intended to be brought about”, BUT “effect” can also be a verb meaning” to bring about” or “to produce as an effect” or “to bring about” as in: “I effected a modification to the transformer”.
That is, in the most common use, to “affect” (verb) something results in an “effect” (noun) upon it. However, it is also perfectly legitimate to say that you can “effect” (verb) a change or modification, for example. And one can also “affect” a certain characteristic without “affecting” anything or anyone else.
In Spanish, for example, affect (tv) is used more as to influence, to produce a change, an alteration; effect (tv), to accomplish, to bring into being. Those are, in fact, the meanings we attach to those verbs when we try to "think" in English.
Eng-Tips.com : Solving your problems before you get them.
Julian and IRStuff - let me re-phase my question. Where is the verb as in "I can effect a (insert your favorite verb)" ?
TRANSITIVE VERB: Inflected forms: ef·fect·ed, ef·fect·ing, ef·fects
1. To bring into existence. 2. To produce as a result. 3. To bring about. See Usage Note at affect1.
TTFN
Where is the verb that I have shown in bold?
"You CAN NOT cause an affect, nor can you effect a thing (noun)."
was about whether effect was a verb or a noun.
The point is that effect is defined in various dictionaries as both noun and verb. Moreover, affect does indeed had a definition as a noun:
"In psychology, affect is the subjective experience of an emotion. When used as a verb affect concerns the influence of something on a person."
TTFN
Of course... how could I have missed it. My mistake.
“I can effect a (insert your favourite verb)”
NickE must take the credit / blame for this!
What I DID say is that I can effect a “change / modification / repair / etc”. In all cases, “I can effect a (NOUN)” – but not just ANY noun. I think that the noun in question must be the noun-form (is that the correct terminology?) of a transitive verb, and ”effect” changes from being a noun (its usual form) to becoming the transitive verb.
For example:
I can change (verb) something, or I can effect (verb) a change (noun).
I can modify (verb) something, or I can effect (verb) a modification (noun).
I can repair (verb) something, or I can effect (verb) a repair (noun).
IRstuff: Thanks for pointing out the noun form of “affect”. It wasn’t in my Macquarie Dictionary (I checked before posting!), but I had a sneaky suspicion that someone could prove me wrong, which is why I qualified my post with:
“Affect” is a verb (always, as far as I am aware, but someone can probably produce a counter-example).”
http://onelook.com/
It's a metasearch engine for dictionaries and has done wonders so far.
TTFN
I was answering your posts, but only thinking of the original question, so my apologies for not reading more carefully.
TTFN
Thanks for the tip on www.onelook.com - I checked it out, and I have added it to my "Favourites".
(And I've clicked on the "Thank You" button in this thread, so you should get at least one vote this week!)
I was thinking wrong, if change is placed into that phrase then it is a noun, JulianHardy is right in the post a few up.
I mostly don't even remember how to diagram a sentence (shoot turned a noun into a verb again, my thesis advisor hated that), often times I just see that the sentence is wrong and know what word to place there to make it right.
What fun language is, almost as fun as thermo....
nick
IRStuff was not talking to me.
Julian was not talking to me.
Nick thinks that Julian figured out “I can effect a (insert your favorite verb)” is not correct.
Okie-dokie.
Gotta run now. I’m going to go have a conversation with my wall. Nice paint job. Tell your friend we’ll meet at the corner.
(for anyone else my point was to bring up this common misuse that bugs me, I just had a real hard time explaining it. See the following lines from my first post:
"You can affect something and cause an effect.
You CAN NOT cause an affect"
I think I've got them right now. But likely I'm wrong again
nick
"af·fect [ á fèkt ] (plural af·fects)
noun
feeling associated with an action: an emotion or mood associated with an idea or action, or the external expression of such a feeling
blunted affect
[Late 19th century. Via German Affekt .]
TTFN
I think I will suggest it to the forum managers – if I can find the link.
The action I take will affect the outcome.
There is also a recondite use of affect as a noun in psychology.
Effect can be a noun or a verb. Noun:
If I hit my thumb with a hammer, the effect will be pain.
Verb:
An analgesic will effect a relief of the pain in my thumb
JulianHardy
The usual method of clarification is to address a post to a particular user if you feel that it's necessary. The link to contact forum managers is at the very top of each page, marked Contact Us
Good Luck
johnwm
As jmw mentions you can put the name of the person you are talking to in your thread as I did in my 2nd message on this thread.
Irstuff- in post #(3) I have to agree, drinking will leave you with a fuzzy head like I had on Wendsday.
nick
NO IT IS NOT
It is a twenty one point one eight percent increase.
PS ElPete, this is the real JMW. I think you mean JohnWM.
Also sorry to have launched into a little bit of a rant. I didn't like the sentence starting "A lot of confusion has arisen here because electricpete thought....". I probabaly overreacted but I don't think there was ever any confusion on my part in this thread.
So, I plan to stop typing on this thread now and no more comments unless/until someone else says something about electricpete.
Jon
