msr with cement treated subgrade
hello,
first post. i've been asked to investigate the generally accepted range of values of MSR using a cement treated subgrade, with 7% and 12 inches deep. we can assume soft subgrade below the CTB. any help would be appreciated.
thanks,
scott
thanks,
scott
RE: msr with cement treated subgrade
If the unconfined compressive strength of the CTB is over about 250 psi, shear and bending should control the design parameters, not the modulus value.
**Need Professional Development Hours / Continuing Education ??
**Try this course...
http://pdhonline.org/cgi-bin/quiz/courses/courselist.cg...
Please do a search of this site using the key words "modulus subgrade reaction" - you should find quite a lot of information since many others have posted questions regarding this subject.
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.
