How to Create Copy Geom Feature?
I'm trying to create a copy geom feature in one of the parts I have in my assembly.
I've selected modify... part... feature... create... data sharing... and when I try to select Copy Geom I can't because it's greyed out. How/what do I need to do to select it?
RE: How to Create Copy Geom Feature?
sundevil98,
I am pretty sure you can only do this from the assembly mode.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
How do I do it in assembly mode???
That's where I'm having problems. I have an assembly pulled up - but can't figure out how to create the copy geom feature.
While under the assembly menu... If I select Feature.... create... Data Sharing... I still can't select CopyGeom because it is greyed out.
Likewise, in the situation I stated above (trying to modify a part within the assembly).
I should also point out that within my assembly I have two parts... The first part is the part which I wish to copy the geometry from... The second is the part I wish to copy the geometry to.
sundevil98,
Please see if the topic Suggested Technique for Copying Geometric and Datum References (www.ptc.com/cs/cs_23/howto/afe987/afe987.htm) from the PTC Knowledge Base is helpful. Note: You need to be a maintenance paying customer to access this information.
Best regards,
Matthew Ian Loew
Branch Rickey
Hmmmm....
Do I possibly need an Advanced Assembly license to create a copy Geom Feature?
Create first a "published geometry" in the part you're copying from, and use it to create your copy geometry
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
