Steel with 4% Boron
Steel with 4% Boron
Can anyone tell me if low-carbon steel with 4% boron (as used for nuclear control-rods) would still be magnetic ?
RE: Steel with 4% Boron
nick
Thanks for such a rapid response.
Do you definitely KNOW that the iron structure will be unchanged ?
I appreciate that Boron is a small atom, but so is Carbon.
4% sounds a helluvalot to me
- but then, I'm not a metallurgist !!!
Bob
I'm really not sure (i'd give the star back if I could....)looking at the B-Fe phase diagram you should,at temps below 912C still be in the alpha-Fe region.
Go here for the phase diagram....
http://cyberbuzz.gatech.edu/asm_tms/phase_diagrams/pd/b_fe.jpg
Thats about all I've been able to locate....
nick
Boron has only limited solubility in either gamma or alpha phases of iron, so the curie temp and magnetization are only slightly affected up to 8.9%.
Bob167, the 8.9% that hacksaw states is the line where Fe2B intermetallics form....
the Fe-4%wtB you speak of should be magnetic.
I appreciate that this is an area of fairly limited interest. The steel in question was made in the sixties for nuclear use; much has been forgotten and many records are lost. So every bit of information is useful.
Bob
Thanks for your contribution.
I've had great difficulty getting information on this one - the actual owners of the items cannot even be certain what the composition really is !!! So there is a lot of guessing going on. Every piece of information is useful and I appreciate your help.
Bob
the solubility of B in iron is limited.
there is quite a bit of data on FeB, it is just not on the internet.
Sorry to be so long replying; I had other work for the past fortnight but the Boron problem will be back on the agenda when our sample comes back from cutting trials.
The magnetic properties of the material could be an important feature of the work, so thanks for highlighting it.
Bob
Thanks for the tip.
The only snag is that there are two types of components; one is plain mild steel, the other (allegedly)contains boron in some (unspecified) form or other. We only have a sample of one of them and no-one is certain which !!!
(sounds like a question in the Mensa entrance test !!)
But every piece of advice is very welcome,
Thanks again,
Bob
that can be quantified with a simple test.
the best bet is to drop a piece off at the local testing lab. a surface scan is pretty cheap(comparitively).
The item is inside a stainless steel sheath. We managed to reach it with a swiss file and it seemed considerably harder than normal mild steel - but there could be several other explanations for that.
At the moment the sample is away for other tests.
The saga continues .....
Bob
magnetic properties may change significantly while
the neutron adsorption won't change.
<nbucska@pcperipherals.com>
Not quite the answer we were hoping for!! sigh! but even the bad news helps us to determine the strategy that is most likely to succeed.
To be honest, at this point no-one is 100% certain of composition.
Thanks again,
Bob
