Dimension Styles
Dimension Styles
Dimension Styles
In our company, our dimension standard is Imperial inch, with two decimal places, leading and trailing zeroes removed, with the inch symbol (") added. I can set the zeroes removed and the two decimal places as a default but the inch symbol will not automatically be applied to new dimensions. I set the units to decimal and imperial. When I use ft-in as the units the (') and (") always show up. What I do now is I made a dimension favourite with the (") added after the <DIM> but you have to select this everytime you create a dimension. Maybe there is a way to set this as the dimension favourite default or maybe the (") can be added by default somewhere else. Thank you.
RE: Dimension Styles
I believe the standard is all dimensions are in inches, unless otherwise stated. Therefore you do not need to show the inch marks. They can also be miss-read if the dwg is reduced.
I know but we use metric drawings as well and they don't have 'mm' after each one so this is a way to instantly recognize a drawing as imperial.
Sean Nutley
Carmanah Design and Manufacturing
Vancouver, BC, Canada
www.carmanahdesign.com
Dimensions that are secondary are displayed in (), and a dwg note indicating what type they are. This minimizes wording with the dims. This is pretty much standard throughout industry.
