How to clean up parasolid files?
I just imported a parasolid file into Patran but was unable to clean up the model using geometry->edit->feature because the feature list is empty.
I am unable to just import the model as a UG file because the UG version i'm using is NX2 while i think Patran 2003r1 only support up to NX1 or V18.
Is there any other way I can simplify the model?
Another qn is that if I have a box with a cover attached by means of screws, what is the best way to model it? By using common nodes, creating a rigid element between the nodes where the screws are supposed to be or by creating spring elements where the screws are supposed to be?
Thanks & Regards.
Thanks & Regards.
RE: How to clean up parasolid files?
