Drawing rotation for printing
I am trying to print a 22"x34" sheet on to 24" roll through our plotter. Therefore we need to rotate the drawing but we can only rotate the paper. (ie. the 34" is always horizontal but the paper is loaded as the 22" being horizontal.) Switching between the portrait and landscape does not fix this. The only thing I am doing right now is saving as a pdf and printing from there. that can do it properly. My explanation sounds a bit confusing so if anyone needs clarification to help me just let me know. Thanks.
RE: Drawing rotation for printing
When printing in SW 2004, the print orientation may look as it is correct (in SW). However, going back to the "Windows" printer and setting the preferances there, for the portrait and landscape, then returning to SW should fix the problem.
-or-
Change the switch in the print dialog box "system setting" or "document setting". I perfer system setting. No screw ups because of SW.
- using actual plotter drives, with custom paper configs for SW
- using correct plotter settings (hardware configs)
You should also pay attention to the above posts.
Good Luck
