One Way Sprauge Bearing
Can any of you fine men tell me where I can get info on fitting these bearings
For Eg a 10 mm OD bearing , What size hole is it' a 10mm reamed hole or a reamer that cuts 1 thou under size
I want to get it right so the bearing works correctly
Many Thanks
123Cat
RE: One Way Sprauge Bearing
You need to refer to the manufacturers data and take his reccommendations, there are many manufacturers of sprag bearings / clutches and although they may all be similar it pays to take there advice respective to their product.
