display colors of different mesh parts
Hi.  I generated a mesh of several parts.  But all parts are in the same color(cyan) in Abaqus mesh module.  My quesiton is how to display different the parts of different colors. Could anyone give some suggestion? Thanks
RE: display colors of different mesh parts
I can't see it in CAE but if you run the analysis, or just do a simple data check on it, then you can view the mesh in different colours in Viewer under Tools/color code.
Your only option in CAE is to view the mesh of separate instances using the display group manager. At least then you can view each part mesh.
corus
