Linking detail view callout
Ok here is a good one for you guys. Say I have a view on sheet 4 referring to a detail view "See Detail A-A" on sheet 8. Is there a way in SW 04 to make that txt "See Detail A-A" a direct link that will take you to sheet 8. I think it would be easier for checking if you could just straight to the sheets to see the view being called out.
RE: Linking detail view callout
FAQ559-863
