Where I can find this steel?
What is steel grade?
High strength, low alloy, fine grain
Carbon            .08 to .1 %
Manganese        .50 to .75%
Phosphorus, max    .04%
Sulfur, max        .05%
Silicon, max        .30%
Copper, max        .03 to .04%
Columbium        .01 to .04%
RE: Where I can find this steel?
For the HSLA steels in the US you also need to specify the strength. Normal specifications are given in a similar form to:
090xlf
Where:
090 is the yeild in ksi
x means a 10ksi or better spread btw. yield and tensile
l means low carbon, <.13%wt
f means manufactured to fine grain practice.
nick
