Bluebeam pdf resets my drawing orientation?
Hi all,
Here is the problem. SW2003 sp5.1 with blue beam pdf creator (bbpc) sp 2.2.1 . After I use BBPC my drawing is re-oriented into the "portrait" not the "landscape" that I want. It keeps doing this and I can not stop it. I have to reset my orientation every time before printing the file from SW back to landscape. BTW my drawings from BBPC come out with the "Landscape" orientation, just like I want.
Help me please. Thanks in advance.
A-
A-
RE: Bluebeam pdf resets my drawing orientation?
Also I am using "use document settings" and "scale sheet to fit paper" on the "page set up" page.
A-
King of makes me wonder if Bluebeam might be spyware as well!
A-
It seems that the problem was diagnosed to be a SW issue. They tested it with BlueBeam installed and NOT installed. The problem remained. It seems to have something to do with changing printers, and the settings don't return correctly.
I will sumbit Bluebeams response to SW as a enhancement request. (who knows.. it may already have been addressed.)
I have a work around. Path of least resistance... By setting a key board shortcut to "print preview" as "shift-p", and doing a double return key to accept it, I can "see" if there is a problem before printing. It is crude but works well.
A-
