Raster Images
Raster Images
Hello all
I use aerial photos in my drawings. Recently, when printing these drawings, the aerial photo will have evenly spaced white lines running vertical through the photo. Does anyone know what is going on? How to fix it? It appears some of the pixels are skipped and consequently nothing is printed. Any help is greatly appreciated.
Scott
Scott
RE: Raster Images
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
RE: Raster Images
I'm not sure what caused the problem, but I detached the image then reinserted it. It prints fine know. I think it may have to do with the memory required to process the image. When I was having the problem, the image was processed 16 times before it actually started to print. After reinserting the image, it was only processed 6 time. I should mention that I originally used the image insert under the map menu, (I have Autodesk Map 5). I used the insert raster image when reinserting. I guess there could be a problem there as well. Who knows, I,m going to add memory to my computer and run somes tests to see if it happens again.
Scott
RE: Raster Images
RE: Raster Images
