Elaborate bolt hole pattern
What is the solution for an elaborate (not symmetrical) equally spaced bolt hole pattern?
Thanks in advance
Enduro99
Thanks in advance
Enduro99
RE: Elaborate bolt hole pattern
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Then as Ben said make individual holes and use Point onto Point constraint for place ment and pick the sketched holes.
I usually put the Dimensions for the Bolt holes in the sketch to make it easy to change the holes. When creating your holes use the Sketch dimensions for hole diameters and depths.
To speed up the process use the copy&paste feature operation then all you need to do is hit ctrl+v and pick the surface and sketch entities to place your holes.
Although you can have ofset instance patterns this method is easier to modify parammetrically.
Michael
Attn: cowski, a rectangle with filleted corners with 180^ arcs centered on two of the sides. I guess it can be broken down symmetrically, whats your idea?
Thanks in advance
Enduro99
Of course, if things change so the pattern is no longer symmetric it may take longer to redo than the individual holes (or sketch). Depends on your design intent.
