No open file dialog box
Yesterday it was working fine now (this morning) when I go to open a drawing either from a short cut key of "file-open" it doesn't come up with the std. dialog box but it pushes the command in to the command line.
"enter name of drawing to open <.>:
Im using ACAD 2002map and I want the dialog box back, I did know of a setting that switches dialog boxes off, but I cant remember it.
thanks in advance.
cheers,
RE: No open file dialog box
Hi...
You change the system variable FILEDIA to 1
cheers,
