Cannot change the CL output directory for ASCII
How do I change the default directory that comes up when I post process a file and in the CL output ASCII it has a default direc when i change the directory it says not a valid filename.
Is there some sort of custom settings and where would it be located...
Thnxs.
T
RE: Cannot change the CL output directory for ASCII
in the $SDRC_INSTL/nc directory there is a file called
.mfg_param, in this file are some parameters where
you can set the default CL directory to be where you
want it. this file can also be copied to your local
home directory and be unique to each user.
I-DEAS sometimes is a funny software. Your problem might be that directory name has a space in its name. Try to point to directory withouth sapce ie "My_CL_Files"
Best regards
andrzejls
