How to connect PVC & Steel Pipe?
What do we use to connect PVC & Steel pipes? Pipe expansion required? Would that effect the insulation? Can the transition be within the concrete (thrust block) from outside to inside the building? This application is for Chilled Water Supply and Return.
Thank you
RE: How to connect PVC & Steel Pipe?
  You need a mechanical joint transition fitting. Measure the outside diameter of both pipes, then click the link below to find what you need. The fitting should not be installed IN the thrust block, and there are insulations that can be applied wet, that will dry around the fitting.
http://www.jcmindustries.com/connection_fittings.html
Bolted flanges have also been used.  Flat face flanges with full face gaskets are recommended to minimize the PVC flange stresses.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
willis (Agricultural) Feb 19, 2004
_________________________________________________________
I went to that link, I chose http://www.jcmindustries.com/JCM%20Steel%20Couplings.pd...
Steel transition couplings. Am I right? Steve Braun, do you have any suggestions?
Thank you so much
