Screening Tools for Piping Systems
I have a closed drains system on my platform that is fully welded from start to finnish of diameters varying from 2" up to 10" diameter.  There is approximately 5 miles of pipework in the system.  It has multiple elbows and branches and has been in service for 23 years.
I know that there are SRB's in the pipework and need to screen the system to target inspection.
Does anyone know of a quick and reliable method?
RE: Screening Tools for Piping Systems
What comes to mind:
1.  Portions of the closed drain system upto 4";
    RT-DWDI; you can readily identify corrosion
    across the pipeline wall.
2.  Thickness and or flaw detection survey.
    2.1  Guided Wave-UT to cover considerable pipeline
         lenght. (assess material loss)
3.  Hydrostatic Testing.
4.  Assuming portions of the pipping is U/G ; DCVG/CIPS
    to survey the coating system.
5.  Pipeline profile (Low/High Points) prone to fluid
    accumlation or stagnant conditions.
The above can be utlized to a level of coverage that would
provide assurance; in combination of or all.
Cheers
PVRV
Thanks for the info.  We have already done random UT & Radiography and found problems.  I am looking at GUL & LORUS at present but have lots of branches & elbows to contend with.
SLOFEC is another option?
Cheers
Jim
