Gate valves for LNG
Gate valves for LNG
Gate valves for LNG
could you help me to find a valve supplier in the UK or europe for 8 x 6" gate valves butt weld ends schedule 40 for use on LNG @ 10 bar temp minus 165 centigrade
RE: Gate valves for LNG
Piping Classification Specitication varified shall have the the following Valve for Cyrogenic Services
Description of GATE Valve: (1/2 -to- 24)
Type:    GATE (CRYOGENIC TO -325ºF)
Class:    150
Ends:    RF FLG
Body/Bonnet:    SS (ASTM A351-CF8M)
Trim:    316 SS, HARDFACE SEATS, API 600 TRIM #12
Design:    OS&Y
Operation:    HANDWHEEL
Bore Port:    FULL
Bonnet Type:    BOLTED, EXTENDED BONNET FOR CRYOGENIC SERVICE
Stem-Packing:    CORROSION-INHIBITED DIE-FORMED FLEXIBLE GRAPHITE
WITH ANTI-EXTRUSION RINGS
Wedge Type:    SOLID or FLEXIBLE WITH CAVITY VENT TO HIGH-PRESSURE SIDE
Gaskets:    API 600
Bolts/Nuts    MFG STD
The standards are:
DESIGN        - ASME B16.34
ENDS        - ASME B16.5
RATING        - ASME B16.34
Leonard Thill
www.thill.biz
Hi 1BT
Try this co:cambrian valves in the UK They are pretty good at sourcing specials. Their email is cvalves@aol.com
Any advise on where to purchase ASME B31.3 in the UK.
      As far as I remember, "FASANI" in Italy manufactured that kind of valves... for the distribution in UK, I found "Tyco Valves & Controls Distribution (UK) Ltd" in Market Harborough. Take a look at
    http://www.kellysearch.com/gb-company-45000149.html .
Hope this helps,        'NGL
1BT
Poyam of Spain
Orion of Italy
have a good product line for LNG valves
Raimondi (now part of Tyco) used to do them but this line I think has been pass to the Fasani plant (again Tyco)
1BT,
    below you can find all the adresses of the Italian Companies mentioned by JGPeck:
        *    RAIMONDI
        http://www.raimondi.it
        Via Castellanza, 47
        20027 Rescaldina (MI)     Italy
        Ph.:     +39 0331 575111
        Fax:     +39 0331 464772
        E-mail:     raimondi@raimondi.it
        *    FASANI
        Via Simonotti, 20
        28010 Briga Novarese (NO)     Italy
        Ph.:    +39 0322 94333
        Fax:     +39 0322 94964
        *    ORION
        http://www.orionvalves.com/
        Via Caboto, 8
        34148 Trieste (TS)         Italy
        E-mail:     orion@orionvalves.com
