Reading single Char from String in C.
I am new to C and I'm having a problem with something I thought would be relatively simple.
I am trying to read a character at a time from a string, using the getchar() function, and I seem to be having alot of trouble.
Below is my code:
FILE *fp0;
char c(10+1);
int j, ch;
fopen(fp0, "outfilename","w");
for ( j=0 ; (j<10) && ((ch=getchar()) != EOF) && (ch != '/n') ; j++)
c[j] = (char)ch;
fprintf(fp0, "c = %c/n", c[j]);
fclose(fp0);
This compiles okay, but hangs up when it's executed.
Any help would be greatly appreciated.
mjs84
Below is my code:
FILE *fp0;
char c(10+1);
int j, ch;
c[j] = (char)ch;
fclose(fp0);
mjs84
RE: Reading single Char from String in C.
I forgot to mention. The string I am trying to read is in a string variable.
char str1[10+1];
str1 = "123H.456";
Is this kind of initialization even allowed? (parentheses as opposed to brackets)
Can't remember if order those pieces are computed in are guaranteed to be left to right, and if not, (ch != '/n') may not do what you think it should do.
I had initialized it
char c[10+1];
I did get this to work by writing my string into a temporary file and using the getc() function to read each character of the file.
This seems to work okay.
If there are any better ideas, I would sure like to hear them.
mjs84
I think that the problem is the castings of the variables.
ch is cast as int. In your for statement by doing
comparisons as characters, the program seems to work
correctly. I've modified you program (I hope that the
formatting doesn't get screwed up......
Hint: When in doubt, throw in a printf statement
#include <stdio.h>
main(){
FILE *fp0;
char c[10+1];
int j, ch;
fp0 = fopen("outfilename","w");
//for ( j=0 ; (j<10) && ((ch=getchar()) != EOF) && (ch !='\n') ; j++)
for ( j=0 ; (j<10) && ((char)(ch=getchar()) != EOF) && ((char)ch !='\n') ; j++)
c[j] = (char)ch;
// printf( "c = %c\n", c[j]);
fprintf(fp0, "c = %c\n", c[j]);
fclose(fp0);
Thanks for the help. I'll try it and let you know if that does it.
Thanks to all who give this valuable advice.
mjs84
