Big geometry
Big geometry
Can anybody write: How can I see the bigger more difficult geometry in shaded mode? What should I switch off or on? What should I change in the settings? (The problem is, thje speed of the regeneration of the screen!)
Irwin
Irwin
RE: Big geometry
rjw57
RE: Big geometry
I tried these layer and switch off/on versions. Yes in this case a little bit faster, but in the case of surfaces there is no effect. If I put all surfaces in one group the refreshing is still slow!
Our distributor has no idea about this problem!
Please help!
Irwin
RE: Big geometry
RE: Big geometry
Ervin
RE: Big geometry
Try this page. I got it from a forum of folks that use FEMAP...
http://home.comcast.net/~rjw57/interest.htm
Check all of your drivers for proper OpenGL support, make sure you have the latest drivers, etc...
Good luck
