High temperature insulation unaffected by water absorption
Does any one know of thermal insulation workable to 1000 degrees F whose insulation value is unaffected by water absorption (note: not just high humidity)? I will be truly appreciative of any help in this regard. Thanks.
RE: High temperature insulation unaffected by water absorption
You need to explain a bit more.
How is moisture going to be present at 1000 deg. F?
