"Newbie" 3Ph windings to RPM?
Hello to All
Please forgive my lack of knowledge on this subject.
Leeson 3ph motor
No Tag
Output Shaft Dia. 1.125
Rolled Steel Housing: Length 9.500 X Width 8.375
Squirrel Stator
There are 36 steel bar segments, there is a group of 3 segments to wich each segment has a large amount of copper wires crimped into it, as i trace this 3 segment section to  where it goes into the next segment of 3 bars is at 90 degrees.
There are (9) t wires coming out of the junction box.
What would the RPM be of this motor, and is there anyway of finding the HP.
Secound question this motor is for a large disc grinder that will have a 22" disc, the input shaft to the disc is 1 15/16".
I would like to turn the disc at aprox 1450 RPM, any help on sheave size for this application.
Thank You, for any help
Chris
RE: "Newbie" 3Ph windings to RPM?
http://www.leeson.com/
or have you already tried them? Customer service doesn't always charge for services. Why not e-mail a pic of it to them?
Groups 90 degrees apart sounds like a four pole motor!
At 50hz that would be around 1425 rpm, 1750 for 60hz.
Can you post a link to a picture of the windings?
Suggestion: Contact Leeson tech support. Also, it may be brought to a motor repair shop for establishing the power ratings and windings configuration.
Hi
Sorry about the delay, I can email pics of the windings to anyone if this would help to I.D. the motor.
Thanx,..Chris
Posting an email address is a "no no" on this site. You will have to put your pictures on a home page and post the link!
Suggestion: What about faxing the pictures?
