revcloud error
revcloud error
revcloud error
I have just started getting this error, any ideas???
Command: APPLOAD revcloud.lsp successfully loaded.
Command:    REVCLOUD loaded. Type REVCLOUD to draw Revision Cloud,
   to close, return to starting point. For additional Help - RCHELP
Command:
Command: REVCLOUD
; error: no function definition: INIT_BONUS_ERROR
Command:
RE: revcloud error
Hi...
You have the Express Tools?. The error can be because you are loading a routine of the Tool Bonus of AutoCAD R14.
RE: revcloud error
what version are you using??
RE: revcloud error
Are you using ACAD 2000 or higher?  Use the Express-tools revcloud, not the Bonus-tools version.  Go to the FAQ tab above and download the Express-tools.
Flores
RE: revcloud error
ACAD 2002 map,  I found a copy of the express tools on the net, (possiabley the same one I was using before).
Reloaded it and it seems to work fine now. It might have just been that a file got corupted.
cheers,
