Riveting Anodized Aluminium
I am about to specify solid rivets on a black anodized aluminium sheet part. There is very little stress on this, but it should look good and I do not want corrosion. Can I have this thing riveted and then anodized, or should I have the rivet installed afterwards, and specify a relatively non-corrosive aluminium grade for the rivet?
My application is not absolutely critical at the moment, but I may have something similar later that will be critical. I would appreciate any tips, or a pointer to some literature or a website.
Thank yo very much.
JHG
Thank yo very much.
JHG
RE: Riveting Anodized Aluminium
If I am not wrong, anodizing after riveting may cause some of the anodizing compounds (acids etc.) to be trapped between the rivets and the sheet and may promote future corrosion.
In my company, we drill the holes for for the rivets, anodize the hole and around the hole and then install the rivets. Usually, the rivets are a finished product, which meand that they are already protected. I don't have experience with the black aluminum sheet, but I don't see how it would matter.
Coka
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
If I am not wrong MIL-A-8625, Type III, Class 2 used to ask for 336 hr salt-spray tests. Is there any change in AMS-A-8625 which replaced MIL-A-8625?
Ray Reynolds
JHG
I omitted a very important word in my previous answer. What I ment to say is anodize TOUCH-UP, which is different from the anodizing process. You have an anodized aluminum sheet, which means that the surface configuration was changed. The anodize touch-up is applied with a brush, and there is no surface configuration change. The anodizing process is better then the touch-up, more durable, deeper corrosion protection, but the touch-up method is also widely used. If you want to anodize your aluminum sheet, you would have to strip the original anodizing, drill the holes, and re-anodize the plate. It all depends on the application of your plate, but usually the touch-up is enough.
Coka
