how to measure steam flowrate
HI, im carring out a steam balance and I need to calculate the steam flow rate of the equipments. I only have the pipes diameters and the pressure. If i had the steam velocity I would be able to calculate the flowrate with the diameter. Hoy can I determine the flowrate only with the diameter and the pressure?
RE: how to measure steam flowrate
I do not believe that you can....
MJC
Eng-Tips.com : Solving your problems before you get them.
