What is the tolerance for the starting voltage test in a motor?
How can I find the tolerance for a synchronous motor in a dryer concerning the starting test voltage?
For the heating test the tolerance is +-10% of the nominal voltage.
But for the starting voltage ?
RE: What is the tolerance for the starting voltage test in a motor?
Check IEEE Std 115 "Test procedure for Synchronous Machines" Part 7.1.3
http://standards.ieee.org/catalog/olis/emach.html
for the above referenced standard.
Also, check NEMA MG-1 Standard.
