Properties of Heat Affected Area
Please excuse my ignorance on this subject but I am just starting to investigate some finite element modelling of a two welded steel parts. I am particularly interested in some high stress readings we have noted in the vicinity of the weld. Could anyone give me some figures or tell me where I might find information on suitable values to plug in for the mechanical properties of the heat affected area? The steel being used is referred in drawings as UNI 7070 - FE 510 C.
RE: Properties of Heat Affected Area
The hardness values can be correlated to other physical properties to plug into your model.
