Transite Pipe Gasket Material
For any of you old timers out there:
Does anyone have information regarding the type of rubber gaskets that typically that would have been used for chilled water applications using transite pipe?
We have a chilled water system renovation project that has about 1000 feet of underground transite pipe and would like to convert the system to a 15% propylene glycol and water solution. We are concerned about the rubber gasket compatability with propylene glycol.
