sketch lines disappear
During the construction of a sketch with grid snaps on, it seem the lines I create get hidden behind the grid
under intensified lines. I can always move the entire sketch as a unit away and in between the grid lines of course, and then I can see the lines, but I was wondering if anyone knows how to stop this from happening. Not a big deal but it has been bugging me for a while.I tried to change the sketch line width but I was not able to affect the sketch elements I was creating. By the way this does not happen if I use the profile tool to create the lines. It only happens when I use the line command.
thanks
Ninpo
thanks
Ninpo
RE: sketch lines disappear
can u give info about V5 release / SP ? windows or unix level...
graphic device and resolution used...
thks
Eric N.
catiav5@softhome.net
It is windows XP v5 rel 11 500x500
Do you have the same pb if you work with 1280 x 1024 ?
Eric N.
thanks
Ninpo
Tools + Options + Mechanical + Sketcher
In the Grid section on the top; turn off the DISPLAY option and also the SNAP TO POINT option
Are you working with several parts within a product, and have you changed the colors of those parts? I've noticed that when I change the color of a product or a part, all the geometry in my sketches turn black. If this is the case, just change the graphic properties in the products and parts to NO COLOR.
....Jack
Eric N.
hercules 3d profit
Nin
