PI testing on 13.8 kv motors
Is there any value in doing a 5000 volt PI test on a 13.8 kv motor. Even if the readings are trended?
RE: PI testing on 13.8 kv motors
VLL(vac) Test Voltage (vdc)
<1000 500
1000-2500 500-1000
2501-5000 1000-2500
5001-12000 2500-5000
>12000 5000-10000
5kvdc test of 13.2kv machine is consistent with these guidelines. We use 10kv test at our plant. I don't think using 5kv would be a big problem (there may be slight tip-up if contamination is present). Most important thing for trending is to use the same voltage each time.
See Thread " Generator PI Value Problem" 01/10/04 by edison123.
http://www.ieee.org
