Ultrafiltration
Ultrafiltration
Hi guys
We're trying to install an ultrafiltration plant to treat rain water and backwash water from sand filter, the problem we are facing is that the back wash water contains human hair and skin, any advice on how to deal with the prblem.
thanks
thanks
RE: Ultrafiltration
Take a look at www.kochmembrane.com
brennans7
RE: Ultrafiltration
Thanks for taking the initiative of answering my question.
The membranes are of hollow fiber-capillary type, each fiber contains 8 capillaries with 1 mm Dia.
RE: Ultrafiltration
If you are stuck with the HF membrane, what type of pretreatment are you using? You could install a backwashable pre-screening device to screen the solids out prior to UF.
See the following links:
www.amiad.com
www.filtomat.com
RE: Ultrafiltration
We're also installing a GAC filter.
We're going to run the system and see how it goes!
