Any suggestions on using connections to limit movement?
This is hard to describe what I am trying to do.....I will simplify it some.
I have a plate that will push on an I-beam.
There are no physical connections, (bolts or welds)
This should allow the thick plate to remain stiff, while the I-beam deflects.
If I run the FEA with Pro/e defaults, it thinks the large plate and I-beam are welded, thus stiffening the I-beam.
I set surface connections between the two, with the same results.
I then set a gap between the two, and applied the connections.  This then allows the plate to push through the I-beam, like it wasn't there.
Any suggestions?
RE: Any suggestions on using connections to limit movement?
ppgregar,
You will want to set up a contact region between the two contacting surfaces.
Check the PTC Knowledge Base.  Look under the Support Tools heading on: www.ptc.com/support/support.htm. Note: You need to be a maintenance paying customer to access this information.
Here is a link to topics on “contact region”:
(www.ptc.com/appserver/cs/search/kdbresults.jsp?lang=en&...)
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
