Poisson and Modulus of Elasticity of Al 2024 T6
Hi
Nowhere near my reference books.  Anybody have Poissons and Modulus of Elasticity for Aluminium 2024 Bar diameter 35.5mm in the T6 condition close to hand.
RE: Poisson and Modulus of Elasticity of Al 2024 T6
Per the Aluminum Association:
Typical Average Modulus of Elasticity: 10,600,000 psi
Note: the Compressive Modulus is typically about 2% greater than the Tension Modulus.
Note: the Aluminu Association draws a distinction between "Minimum" and "Typical" properties.  Typicals tend to be about 15% higher than Minimums.  Use Minimums for design.  Then again, I think this just refers to strengths, not modulii.  Oh well...
Per "Aluminum Structures" by Kissel and Ferry:
Poisson's ration: 0.33
Cheers for the info guys
I use modulus of elasticity for thermowell calculations.  The modulus of elasticity varies with temperature.  I will check to see if I have Aluminium 2024 on my spreadsheet but cannot get to it now.
John
I list A92024 but lack the data but have data for A96061.
Spec    UNS         Modulus of Elasticity Values (X10**6 psi) (Young's Modulus)
Type              At Metal Temperature (deg F) Not Exceeding
Grade         Material    -200    0 - 100    300    500
SB-221    A92024    Aluminum
B211    A96061    Aluminum    10.8    10.5    9.2    8.1
Various Sources, ASME B31.1, B31.3, "Physical and Mechanical Properties"
John
