Catsettings files
Catsettings files
Catsettings files
Will anyone provide step by step instructions and or commands on how to clean or ( delete ) the catsetting files that I hear cause so much problems.
thank very much for your help.
RE: Catsettings files
Hello Ninpoikan,
You have to find the directory of your settings first.  It can be local or on the network, depending how Catia was setup.  You can go to the Catia tools in the window menu and chose the environment editor to find this information.
Here is a typical installation path example:
C:\Documents and Settings\youruser\Application data\DassaultSystemes\CATSettings
Once this done, here is what I suggest:
Delete all the files in this folder.  Restart Catia and all the toolbars and options will be back to default.  Use Catia for a day and put all your toolbars and settings the way you like them.  Close Catia then copy your CatSettings folder somewhere for backup.
When you don’t like your settings anymore, just replace your folder with the backup one.  I like to create a batch file that does it that looks like this:
del "C:\Documents and Settings\youruser\Application Data\DassaultSystemes\CATSettings\*.*"
xcopy "backup\CATSettings\*.*" "C:\Documents and Settings\youruser\Application Data\DassaultSystemes\CATSettings\"
Then start Catia or put a line in this batch file to lunch Catia automatically.
Hope this helps!
Alex Laurenceau
Instead of copying your catsettings back into the catsettings directory, you can add a line in your environment file so Catia will read the backup directory first, then your user directory. When later the S**T hits the fan, you jjust delete the user catsettings directory and everything is back to whatever you consider normal
The file you need to edit is CATIA.V5RXX.BXX.txt (XX is your version number). If you don't know where this file is located you can right-click on the Catia icon on your desktop and look for the path after the -direnv variable
In this file, look for the line starting with
CATReferenceSettingPath=
and enter the path to your backup directory right after the equal sign.
Hope this helps too! Now I'm of for the weekend
Ola Gabrielson
Praktisk CAD
hi,
after setting the ENVIRONMENT you should define default CATSettings with the admin mode of V5 (position of toolbar...)
Then exit the admin mode and use CATIA as usual
RTFM...
Eric N.
catiav5@softhome.net
