purge or to delete dimension styles
Is it possiable to purge or to delete dimension styles in autocad 2002???
RE: purge or to delete dimension styles
Sure.  The purge command does it, but only if it is not being used anywhere including blocks and xrefs and is not the current style.
You can also delete them from the "DIMENSION STYLE MANAGER".  Just left click on the dim style and then Ctrl-Delete.
Steve Smith, C.I.D.
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
