Software That Calculates Section Properties
I am using Shape Builder to calculate section properties of complex shapes. However shape builder is limited to predrawn shapes and the program does not allow you to draw your own shapes. does anybody know of a more flexible program.
Thanks.
Thanks.
RE: Software That Calculates Section Properties
such as -algor -ansys -pro/e etc.
and a simple way is use acad
when you draw a object , define it as "region"
and you can use query "mass property" to get it
good luck:)
The results can be exported in text file format so you are not limited to just using this package with the bigger Robot system.
Look in
www.risatech.com
They just came out with a section property program.
Also, in ShapeBuilder, I believe you can piece together various rectangular shapes to get almost any shape you want.
If you are doing FEA, then the FEMAP pre/post processing software has a nice utility built in for this.
I have been using AutoCad for 10 years. I knew about the area and the perimeter but I never experienced Mass Property. This is great. Thanks for a great tip. And thanks for Eng-Tips...
Do you have contact information for the software you have listed
Jae.
I will definitely check on this software.
If you use complex shapes with shape builder the presentation of the drawing is not good. But the program is great in finding values .
Thanks for the tip. However I have one question.
How do you find the center og gravity for the drawn shape in autoCad.
Thanks.
I was able to find out how to calculate the center of gravity in AutoCad. Thanks ....
The MASSPROP command will give the x,y,z coordinates of the centroid, which is the same as the c.g. A sample of the MASSPROP command is shown below:
Command: massprop
Select objects: 1 found
Select objects:
---------------- REGIONS ----------------
Area: 3.6740 sq in
Perimeter: 22.2938 in
Bounding box: X: 0.0000 -- 4.0000 in
Y: 0.0000 -- 4.0000 in
Centroid: X: 2.0000 in
Y: 2.0000 in
Moments of inertia: X: 24.7033 sq in sq in
Y: 17.8741 sq in sq in
Product of inertia: XY: 14.6959 sq in sq in
Radii of gyration: X: 2.5930 in
Y: 2.2057 in
Principal moments (sq in sq in) and X-Y directions about centroid:
I: 10.0075 along [1.0000 0.0000]
J: 3.1783 along [0.0000 1.0000]
Peter.
I am using the ShapeDesigner software to calculate the section properties and the stresses analysis it's really very interessting and flexible we can import dxf complexe geometry etc.. and calculates also the tosion (J) and warping (Cw) constants.
i hope this helps
James
Note in the above example by butelja that the 0,0 point is at the lower left of the shape as indicated by the bounding box. This means the product of inertia and radii of gyration will be computed about the lower left corner and not the cg which is what you want for calculations. I always do this in two steps. First run MASSPROP to find the cg, then move to the cg and run the MASSPROP again.
When done I generally cut and paste the info from the command window into the drawing and print out for my records. If I don't move the cg I found it is too easy to forget the radius of gyration shown is not correct for stress calcs.
-Mike
As I scanned through the messages again I realized that I had missed the point you made in your first post in which you explain the centroid 0,0 location issue. Sorry about that.
A momentary lapse of reason.
-Mike
I have a simple program that calculates section properties - moment of inertia, centroid, plastic section modulus - by inputting node co-ordinates of your cross section - solid or with holes.
Viraf
