thread diameter and pitch for valves
On a high pressure 200 bar nitrogen cylinder there is a threaded port 24,40 mm diameter 14 tpi.
Which stsndard or denomination cover such thread??
Any help , welcome.
Thanks in advance.
Pardal
RE: thread diameter and pitch for valves
I'm not an expert at gas cylinders, but I do recall that they folow Canadian Gas Association (CGA) and DOT (Department of Transport) standards.
I think it is CGA Pamphlet V-1, Compressed Gas Cylinder
Valve Inlet & Outlet Connections and/or CGA Pamphlet V-9,Standard for Compressed Gas Cylinder Valves
Where I can see such brochures.???
Any web link??
Pardal
I'm sure you'll have to buy them - they should be listed in their publications
www.cganet.com
Thanks I will see.
Pardal
