Can't delete a surface
I have a part where at one point, I have offset a number of surfaces. I now want to delete them. I have deleted all but one, which keeps giving the error message - surface cannot be deleted.
Why is this happening?
Paul.
RE: Can't delete a surface
I believe that error occurs when you have a surface that is being used in the current model. I have seen surfaces that you cannot delete, and that surface is usually being used as the trimming surface. I just hide the surface when I can't delete them.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Right-click on the surface in the feature tree, and investigate the parent-child relationships.  If there are child features, edit them so that they have no link to the surface you are trying to delete.
"Great ideas need landing gear as well as wings."--C. D. Jackson
http://www.EsoxRepublic.com
Sorted.
Thanks chaps.
