Superelevation
Superelevation
Superelevation
Hi all,
I'm looking for work examples for superelevation especially on reverse & compound curves for both circular & spiral curves. The curves i'm dealing are pretty 'tight'; the straight section between two curves is very short or non-existing. The radius are ranging from 200 to 600 feet.
Thanx in advance
corey
RE: Superelevation
Hi, longisland:
You might find examples of these curves on Mannering's book:
Principles of Highway Engineering and Traffic Analysis.
Also, you need a certain distance between curves in order to perform the change of superelevation in the curve to the tangent. The maximum percent inside of change inside the curve I would think of is 50. I would try to reduce the radius of the curves.
Hope this helps,
Roberttx.
RE: Superelevation
If longisland is on Long Island, NY, right-of-way costs are probably astronomical. Solutions  short of realignment would be much preferred.
      "Come to think of it, there are already a million monkeys typing on a million typewriters, and the Usenet is NOTHING like Shakespeare.
        Blair Houghton
