DSMU Tip... (proimgr)
Here's an odd one... but it happens...
If you can not run the DSMU correctly while connected... well... you have to change a taskmanager setting before logging in!...
Start the DSMU (aka proimgr.bat)... (start it and leave it running)...
Go to the Taskmanager...
Find the Task listed as Wish.exe...
<Right Click> on it...
Choose to "Set-Affinity"...
you should see that there are 4 CPU's listed with check radio boxes...
Uncheck any two!...
close out... and go to the DSMU you have open... and log in...
No more problems...
NOTE: You have to do this every time!... shitty...
If you know a better way.. let us know...
Uncheck any two!...
No more problems...
