Obstructions through ducting?
unfortunately, there is ductwork (say 8' square) in which a structural steel beam will diagonally penetrate.  try to imagine this scenario, an 8' square duct with a structural steel beam penetrating the duct at approx. 22-degree angle.  in other words, when facing square duct, the beam will enter duct at lower left corner of duct and exit duct at mid-height on the right side of duct.  lasty, the beam size is roughly 6-inch square.
that being described and i am currently investigating smacna duct construction stds and ashrae, can anyone provide any arguement (pro or con) justifying this design?  what design criteria (i.e. fig 2-8 in smacna duct construction stds manual) does the responsible individual need to address in the event that no alternatives are avaliable?
other considerations are OSA temps (-60 degF, is beam made of steel that can withstand -60 degF?), beam sealing, and performance issues.  but in this case, a relatively small reduction of air flow (or increased dP) is most likely insignificant.
it is my strong opinion that the engr(s)/designer(s) failed to conduct interference checks, and correct problem before progressing to construction phase.  but this belief is now a moot point.
smacna addresses obstructions, but vaguely and this obstruction is rather unique.
thanks!
-pmover
RE: Obstructions through ducting?
Obstructions do come during ducting and I can't make any comments with obligation point of view. However, you can Y the duct and again join it after the beam. You can keep each branch  with a cross section of 8'x4'.
I will never recommend exposing a steel beam to -60F.
Eng-Tips.com : Solving your problems before you get them.
