Adhesive for Powder Coated Sheet Metal and Polycarbonate Cover
I am helping on a project where we have some sound vibration issues between a powder coated sheet metal panel and a polycarbonate cover. There is some clearance between the sheet metal and the cover, about .025 max in some areas. I need some advice on an adhesive that will stop the vibration between these two parts but at the same time be inexpensive and fast curing, 10 - 20 minutes. I am doing some testing using RTV 162 right now, which will take almost 48 to cure. The application will be on the production line, so any type of adhesive that needs an enclosed environment would not be in our best interest. Any help with some type of adhesive would be very much appreciated.
Thank you!
Thank you!
RE: Adhesive for Powder Coated Sheet Metal and Polycarbonate Cover
http://www.3m.com/adhesives
http://www.loctite.com
Cory
Another option might be some of the new UHB and VHB (Ultra High Bond and Very High Bond) adhesives that are used in a number of construction industries (RV's, etc.). These are a form of tape (without the carrier - so it's really just adhesive on a release liner) that is being used now in many applications in place of rivets (yes, it's that strong). Comes in a number of different thicknesses and can be slit to any number of widthts.
Another option (due to the vibration aspect) is a double-sided foam adhesive tape, though your tolerance of .025" may limit the options. Many of these have very aggressive adhesives as well which should withstand the environment you described and reduce vibration. Tapes are less messy to apply than adhesives too, if that is an issue.
Hope that helps -
